Hi everyone , im sorry for not speaking german,im spanish .
A time a go i installed on my .:R32 mkv a H&r 110 mm coils from Ah exclusive , srs 2,5 wider fenders , Cayenne 6 pot calipers and 17 mm spacers (that the tires dont rub the calipers) . Im on oem wheels , as you know they are 7,5 et51(wheels et51-17 spacers = et34) . Ok thats the introduction .
Now just two questions for the slammed-dropped-stretched masters
1.- I lowered the car about 6 - 7 cm in the front and more or less in the rear . The problem comes when i turn the steering wheel and go over a bump or a kerb (if i go over a kerb with the steering wheel straight there is no problem because the tires stay inside the fenders) because the tires rub the arch fenders and its a bit annoying .
So , how could i fix it ? camber plates ? stretching tires ? both ? one better than the other one ?
Here you are a pic what im talking about .
http://imageshack.us/a/img443/9011/67lu.jpg
http://imageshack.us/a/img809/9413/an6s.jpg
http://imageshack.us/a/img443/5685/7b2d.jpg
2.- Im thinking of going on 8,5x19 , what et do i have to choose ?will i have rubbin problem either front and rear ? what tires size should i mount ? Keep in mind i go with oem rear fenders , not rolled , not worked . Im running now a bit of negative camber because my tires rubbed the inner fender side and now its about 3-5 mm clearance .
Would be great if you could specify all the details , for exmple : 8,5x19 et45 tires 215-35 and it should be fine , or 8,5x19 et42 tires 225-35 and work a bit the fenders ... etc .
Danke schön in advance dudes .
